Water sensor transition to Edge driver?
I apologize in advance if this is a rookie question. I have a bunch of old IRIS water sensors that I removed from my hub and then re-paired to my hub again.
In the app, I see the three dots so I know that they’re using a new edge driver. And in groovy, they show as a placeholder… that all seems good.
My question is in groovy, it shows the execution location as cloud (vs being my local hub). Is that a problem? I thought everything was supposed to be executing locally on the hub under the new infrastructure, hence my question/concern.
The IDE doesn’t accurately reflect the status for devices that have transitioned. If it’s on an Edge driver, it’s running locally.
AFAIK in the app all the devices, edge or not, have the 3 dots. You have to click on the 3 dots and then in the pop up menu if you see the word “driver” it is using an edge driver, if you don’t see the word “driver” it’s not.
