I installed vlc thing following the instructions. I then setup the speaker notify with sound smartapp and tried to play a custom phrase at a scheduled time. When the time came I got an error in vlc saying unable to open "http://s3.amazon….mp3
Looks like it is not able to do the transcribe or something?
Are you hosting the file on s3.Amazon? If so, make sure the file name and path to it are correct. Sorry I am not using VLC thing, but the error leads me to believe the file can’t be found.
I got it to work. The problem was with the version I was using. I uninstalled and installed the latest version, since check for update was not getting me the newer version. It works great now. I set it to do notify with sound when someone is at the front door.
