Hi Andy,
The temperature set point on the virtual controller was below the room temperature, so heater off. If I increase or decrease the temperature selection, keeping it below the room temperature I get…
9734e6b6-ca26-447e-98c5-0333927b849b 14:50:44: debug 'zw device: 03, command: 3202, payload: 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ’ parsed to [name:power, value:0, unit:W, isStateChange:false, displayed:false, linkText:Cabin Heater, descriptionText:Cabin Heater power is 0 W]
485b1ff4-3d38-4a74-ad65-4170e17367f1 14:50:41: info postEventToEndpoint: event successfully posted.
485b1ff4-3d38-4a74-ad65-4170e17367f1 14:50:41: debug Property Change Event switch: off (source: DEVICE)
9734e6b6-ca26-447e-98c5-0333927b849b 14:50:40: debug 'zw device: 03, command: 2003, payload: 00 ’ parsed to [[name:switch, value:off, descriptionText:Cabin Heater was turned off, isStateChange:true, displayed:true, linkText:Cabin Heater], physicalgraph.device.HubMultiAction@56d24aa5]
9734e6b6-ca26-447e-98c5-0333927b849b 14:50:32: debug 'zw device: 03, command: 3202, payload: 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ’ parsed to [name:power, value:0, unit:W, isStateChange:false, displayed:false, linkText:Cabin Heater, descriptionText:Cabin Heater power is 0 W]
485b1ff4-3d38-4a74-ad65-4170e17367f1 14:50:29: info postEventToEndpoint: event successfully posted.
485b1ff4-3d38-4a74-ad65-4170e17367f1 14:50:29: debug Property Change Event switch: on (source: DEVICE)
9734e6b6-ca26-447e-98c5-0333927b849b 14:50:29: debug 'zw device: 03, command: 2603, payload: 63 ’ parsed to [[name:switch, value:on, descriptionText:Cabin Heater was turned on, isStateChange:true, displayed:true, linkText:Cabin Heater], [name:level, value:99, unit:%, isStateChange:false, displayed:false, linkText:Cabin Heater, descriptionText:Cabin Heater level is 99%], physicalgraph.device.HubMultiAction@66d9c415]
So it looks like it switches on the heater briefly, realises it is not needed and switches it off again? This is not a huge issue and it different to earlier when the heater came on and stayed on, but might still be nice to iron out. Either way it seems to be working really well.
The other odd quirk is that I have made the temperature controlled a favourite on the Dashboard of the Android app. It displays the temperature setting but when I touch it, rather than opening the app it says “You are not authorized to perform the requested operation”.
I need to get my head into the coding side of things so I can start do really customise things, and this is a really useful insight.
Many thanks,
Matt
