Apologies if this has been answered before:
I Physical Switches for which I would like to use Virtual Switches. I would like help with code to allow Virtual Switch to remain in same state as the physical switch. For example, if a switch is turned on physically, it would be ideal to see the Virtual switch change state.
If someone has a working code, it would be a great help.
Thanks @JDRoberts … Tried it in IDE but did not work, will try on mobile too. But Big Switch I see is One-to-Many, Not sure if it can transfer state to say On/Off Tile?
You would install the Big Switch smartapp from the mobile app, not the IDE. It works just fine with one master and one slave, it can be one to many but doesn’t have to be.
As long as the On/Off tile is a virtual Switch that has a device ID and is recognized in your network, it should work.
However, you have to first create the virtual device so that both the physical switch and the virtual switch are known to SmartThings. Then you can slave it to the other switch using the Big Switch smartapp.
I must be missing something… I have one on/off Button Tile as master linked to one Physical Zwave switch. When I switch the virtual tile on/off, things work fine. but when I change the state on the physical switch (physically) or on the app, virtual tile does not change state. I am using the Big Switch app as a binder.
Yes @JDRoberts I want Virtual tile to remain in sync wit the physical switch.
I have two types of Dual relay inserts, TZ04 from TLBHOME and Vision ZL7432. I use them with a device driver patched up from Aeon Strip. Virtual tiles make it easier to use. I just need a way by which the virtual tile some how reflects current on of status of the physical relays. I will be using two virtual tiles per device.
There’s something in SmartThings, but I’m not sure exactly what or when, that causes a command to not be sent if ST thinks the device is already in the state being requested. That would stop a loop.
Turn A on.
ST turns A on.
app subscribing to A then tells requests B to turn on.
ST turns B on.
App subscribing to B then requests A to turn on. ST believes A is already on, so ignores the request.
You can see this on the Hello,Home screen: “X was already set as you requested.”
This is actually a problem for me with the lock sometimes, if the tile is out of synch with the lock we have to do a manual unlock.
I also have this problem with Hue lights. Once ST thinks a bulb is on, it won’t send an on request.
