Make Big Turn Off/On Virtual Switch mirror combined status?
I’ve got a virtual switch that runs Big Turn On/Off on a handful of devices. They work great.
Trouble is, used in SmartTiles, they get out of sync with the actual states of the physical devices.
So for example, if the Big Turn ON controls all my outside lights, it’s possible that other routines or ahem when my wife turns off lights via SmartThings, it’s possible for the lights to all be off, while the Virtual Switch shows as On.
Anyone have a fix for this?
I just wrote some code the other day that sounds exactly like this. So give it a try.
For settings sounds like you want:
main switch -> virtual switch
additional switches -> all your other switches
action: both
direction: synced
one on switch: empty
Expected functionality: Virtual switch turns on/off all others. If any of the others turns on by other means, virtual turns on. If all of the others turn off by other means, virtual turns off.
    -Jason-
preferences {
section(“Main switch,…”) {
input “mainswitch”, “capability.switch”, multiple: false
section(“additional switches…”) {
input “switches”, “capability.switch”, multiple: true
section(“Take action when On, Off or Both:”) {
input (name: “type”, type: “enum”, title: “Select when to link action, for:”, required: true, multiple: false,
defaultValue: ‘Off’, metadata: [values: [‘On’, ‘Off’, ‘Both’]])
section(“Control Direction:”) {
input (name: “direction”, type: “enum”, title: “ontomany (main switch controls others)\nmanytoone (main switch is on if any others on)\nsynced (main is both controlled and controls)\nonetomanyoff main on turns only one switch on”,
defaultValue: ‘true’, metadata: [values: [‘onetomany’, ‘manytoone’, ‘linked’, ‘onetomanyoff’]])
section(“one on switch,…”) {
input “oneonswitch”, “capability.switch”, multiple: false, required: false
def installed()
state.main = 0
state.switchesPosition = [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
setup()
def updated()
unsubscribe()
setup()
def setup()
subscribe(mainswitch, “switch.off”, mainswitchOff)
if(settings[“type”] == “Off” || settings[“type”] == “Both”) {
if(settings[“direction”] == “manytoone” || settings[“direction”] == “linked”) {
subscribe(switches, “switch.off”, oneswitchOff)
subscribe(mainswitch, “switch.on”, mainswitchOn)
subscribe(switches, “switch.on”, oneswitchOn)
def mainswitchOff(evt) {
log.debug "main switch: $evt.displayName $evt.value"
if((settings[“type”] == “Off” || settings[“type”] == “Both”) && (settings[“direction”] == “onetomany” || settings[“direction”] == “linked” || settings[“direction”] == “onetomanyoff”) && state.main == 1) {
switches?.off()
state.main = 0
def mainswitchOn(evt) {
if((settings[“type”] == “On” || settings[“type”] == “Both”) && (settings[“direction”] == “onetomany” || settings[“direction”] == “linked”) && state.main == 0) {
switches?.on()
if((settings[“type”] == “On” || settings[“type”] == “Both”) && (settings[“direction”] == “onetomanyoff”) && state.main == 0) {
oneonswitch.on()
state.main = 1
def oneswitchOff(evt) {
log.debug “switch: $evt.displayName $evt.value"
def i = 0
def keepOn = 0
switches.each {
//log.debug “$it"
if(”$it” == “$evt.displayName”) {
//log.debug i
state.switchesPosition.putAt(i, 0)
if(state.switchesPosition.get(i) == 1) {
keepOn = 1
i++
if((settings[“type”] == “Off” || settings[“type”] == “Both”) && state.main == 1 && keepOn == 0) {
state.main = 0
mainswitch.off()
def oneswitchOn(evt) {
def i = 0
switches.each {
//log.debug “$it"
//log.debug i
state.switchesPosition.putAt(i, 1)
i++
if((settings[“type”] == “On” || settings[“type”] == “Both”) && state.main == 0) {
state.main = 1
mainswitch.on()
