Hi
I’m a total noob here and will be buying a SmartThings hub and associated devices shortly. In perusing the forums, I’ve found that customization can be done by Core or SmartRules app (is this correct?). Are there other ways? Is one better than the other?
Thanks in advance.
Welcome!
Core has been replaced by WebCore.
As far as your basic question, the following FAQ should help. (This is a clickable link)
(This is a wiki post: feel free to edit it or add to it as needed. Also, I can’t take any screenshots since I can’t use the app at this time due to its incompatibility with voiceover, so feel free to add screenshots where they would be helpful.)
At one point, one of the biggest advantages of using the SmartThings platform was the wide variety of devices that it supported. However, by the end of 2017 several competing platforms had caught up in that regard.
Where SmartThings still holds a significant advantage over some of the other low-cost home automation solutions is in the ability to really build really complex rules in a fairly simple manner. You won’t have to be a programmer, but you may need the help of other community members to get the logic constructed just right.
Also, you …
Thanks … that was very helpful. I’m not a programmer but can get pretty geeked out about this stuff.
Yeah, that describes about 75% of the people in this community.
