Using Arduino SmartThings with SmartApps
Is it possible to use a command like
zigbee.smartShield(text: "lock").format()
in the Smart App to send the results to the Arduino in string format?
@aproal90 I’m not sure what you mean. Can you go into detail on what you are trying to do?
I’m sorry for wasting your time. I figured it out about an hour after i posted this.
First, I defined and created a handle command in the actual device.
definition (…) {
    command “SendString”
def SendString(String output) {
    zigbee.smartShield(text: “$output”).format()
Then I could easily call this from the Smart App
def contactHandler(evt) {
    switch2.SendString("$evt.value")
no problem! Thank you for posting the answer.
Did you select your device in your smart app? What device capability did you use for your input()?
I’m trying to do something similar, and I can’t call any custom commands.
