Hi All,
I have an Ecobee 3 Lite-- which has worked great until very recently.
I can update the temperature fine from the Ecobee itself AND from the device itself in ST, however, the temperature no longer will set based on any automation in SmartThings. I always want the temperature to be set based on the rules I have in SmartThings.
Details:
In the Ecobee, the temperature is set to "Until I change it."
In SmartThings, the device is set to a hold type of “Temporary”
I have 4 “SmartApps” for the Ecobee:
Bedtime---- should set the thermostat to 63* when heating, 69* when cooling.
I’m Back!---- should set the thermostat to 67* when heating, 69* when cooling.
Z-Ecobee & Living room Windows AM— should set the thermostat to 67* when heating, 69* when cooling.
Goodbye!—should set the thermostat to 61* when heating, 72* when cooling.
Currently, the thermostat just stays at 64* when heating and 69* when cooling-- it completely ignores the automation in ST, even when manually activated.
The only other thing I see is in the Ecobee application itself-- there is a scheduled event (which has ALWAYS been there) with one event per day, the temperatures match the heating and cooling values that the unit has been stuck to, but I can’t seem to delete these events from each day. This was never a problem in the past.
Any ideas on what’s going on or what I’m doing wrong?
