Hello, I need a driver to use this tuya button, someone can help?
This runs with the Zigbee Tuya Button driver from @zambobmaz
His channel invitation is here
https://account.smartthings.com/?redirect=https%3A%2F%2Fapi.smartthings.com%2Finvitation-web%2Faccept%3Fid%3D2d6da83b-ae22-4fda-8af5-bbb8890872d4
Thank you so much, it works perfectly, and for the tuya button with model IH-K663? With this driver i can’t make it work.
The IH-K663 button looks exactly the same right?
As Tuya, with their various manufacturers have differences, probably the fingerprints are not the same.
Try maybe contacting the author of the driver to see if he could add it?
Yeah, the button look the same, okay thanks for the advise, i’m gonna try to contact the author.
I’m using the same button with the same driver, for me the hold press function (3 sec) appears in the smartthings app but is not detected by the driver, you too?
