TTS with DLNA Wifi Speaker and MediaRenderer
(Ahmed) #1
I have a DLNA wifi speaker by Jam. I installed the MediaRenderer SmartApp. When I sent messages to the speaker to play using TTS, the voice isn’t that great. Does anyone know if there is a way to change the spoken voice?
(Andy - United Kingdom) #2
I believe that Big Talker can use different voices…
Andy
(Ahmed) #3
Is BigTalker like MediaRenderer? Right now my WiFi speaker is added via MediaRenderer. Do I have to keep that and then use BigTalker? or will BigTalker be able to detect the DLNA wifi speaker like MediaRenderer did?
(Andy - United Kingdom) #4
You keep media renderer and use Big Talker to play messages through the speakers
(Brian S. Lowrance) #5
MediaRender drives the device(s). BigTalker sends commands to MediaRenderer to speak phrases which MediaRenderer then processes and sends on to the physical devices.
ie:
Contact Opens > BigTalker processes logic and your desired phrase then sends it to your configured device handler (MediaRenderer) > MediaRender processes the commands to speak received from BigTalker and sends whatever commands are needed to cause the physicial device to load the audio and play it.
