Hi,
I registered today as a developer I am trying to write some smart apps or have someone help write them for me who is better skilled in this area.
Here are some of the apps Im trying to create:
SmartApp which Unlocks the Doors When Someone Arrives Home
When Someone arrives home (via Presence sensor or iPhone location) (would be great if you could add multiple people for example 2 sensors and 1 iPhone all in one app)
Which People:
Person 1 (iPhone Location from SmartThings app)
or
Person 2 (SmartThingsPresence Sensor 1)
or
Person 3 (SmartThingsPresence Sensor 2) -
Unlock Front Door (two specified door Locks trigger both at same time not one after the other)
Which locks do want to control?
Lock 1
Yale Deadbolt
http://www.yaleresidential.com/en/yale/yaleresidential-com/Residential/?groupId=1294297&productId=1294299
and
Lock 2
Yale Lever Lock
http://www.yaleresidential.com/en/yale/yaleresidential-com/Residential/?groupId=1294297&productId=1294301
If they are not already unlocked
SmartApp which Makes Sure the Front Door is Locked When you Leave the House and ONLY if the front door is closed
When Someone leaves home (via Presence sensor or iPhone location) (would be great if you could add multiple people for example 2 sensors and 1 iPhone all in one app)
Which People:
or
or
Front Door is Confirmed Closed (via SmartThings Multisensor)
If Front Door is not Closed don’t lock the locks as the deadbolt will stick out and possibly get damaged.
- Lock The Front Door (two specified door Locks trigger both at same time not one after the other)
Lock 1
Yale Deadbolt
and
Lock 2
Yale Lever Lock
If anyone can help out that would be great
Thank-you,
Shawn
