Hi @nayelyz
I am trying to install cli on windows and when i try to run the cli , it will open for about 2 sec and then close by itself .
Sometime the cli stay open but as soon as i clic inside it closed itself .
I Have generate a toke and create config.yaml and paste that token inside .
You used the word “clic” so it may be worth mentioning that you cannot double-click on the CLI from a GUI. It has to be run within a command prompt window.
And you should not have to mess with Node at all. Just download and extract the windows .exe file into a directory on your computer - open a command prompt window - navigate to the directory where you extracted the smartthings.exe file, and run it. The first time you run it, it will open a browser window where you’ll need to sign in to your SmartThings account and give permissions.
