Train Wreck - Constant platform issues
I get your frustrations.
This bug was fixed some time ago but if you’re still seeing it you may need to flush your platform cache to show the controls (exclude and re-pair your device is one way to flush the cache). If you’re using a Z-Wave honeywell thermostat, check out this DTH which gives you access to advanced features of the thermostat including enabling the Automatic switch over feature in the thermostat (amongst others): [RELEASE] Enhanced Z-Wave Plus Thermostat Device Handler - Honeywell, GoControl, CT, Linear, Trane, MCO, Remotec
This isn’t really a ST issue, it’s a mesh or device issue. Z-Wave device report the battery % to SmartThings directly (it’s part of the Z-Wave specs). Many devices don’t accurately report battery levels. ST just reports what it gets from the device. This can also happen for another reason, mesh problems. These are FLiRS devices, i.e. they need buffering devices in the mesh to capture the packets. If you have ghost devices or lack of buffering devices in our mesh, the battery update notifications may not be reaching your hub at all. See this post for more details about ghost and buffering devices: FAQ: why would I need another beaming repeater if my zwave lock is already close to my hub? - #2 by RBoy
You can also use this app to manage your low battery notifications (assuming your devices are accurately reporting the information): [RELEASE] Low Battery Notification with Customizable Alert/Warning/Monitor, Configurable Thresholds and Device Monitoring Alerts
Can you elaborate on this, I don’t understand what you mean by filter settings for devices?
You may want to consider adding mains powered Z-Wave Plus devices. They act as buffering repeaters which not only help improve the quality of the mesh, it also reduces the power level requirements of battery devices and helps improve their battery life. We’ve got motion sensors and contact sensors here which have been running on the same battery for over 7 years now and still going strong. Do you have any specific devices you’re having trouble with?
Can you elaborate?
In addition to what @JDRoberts mentioned, you can also check out ZigBee keypads (they have different features from the Ring Z-Wave keypad, pro’s and con’s for each): [RELEASE] Enhanced ZigBee Keypad Device Handler - Centralite, UEI, IRIS, Xfinity, Scout
Again all this runs in the cloud for now. This may change in future as SmartThings start going more local.
The more sensors you have the faster the batteries will die. 4-6 months is about the typical life but you can extend them further with the right batteries and disabling unused sensors. For example with this device handler and a Monoprice 4 in 1 sensor, you can use Energizer Lithium AAA 1.5v batteries, reduce the sensitivity of unused sensors and you should get 1.5 to 2 years battery life from these devices: https://www.monoprice.com/product?p_id=15902
Alternatively if you don’t need so many sensors and say you need only a temperature and motion sensor, then use this sensor: https://www.monoprice.com/product?p_id=15271
Again, the fewer the sensors the longer the battery life.
The new app automation allows you to set a no motion rule for upto 1 hour. You could use WebCoRE to do this, alternatively you can send in a request to support@smartthings.com to add the ability to set a motionless duration of up to 24 hours (I think many folks may want this feature).
For same reason as above, I don’t think this has anything to do with the hub or platform. If these are SmartThings sensors, you may want to check out alternative devices, even mobile phones using the SmartThings mobile app as a presence sensor or Life360 as a presence sensor.
Try using the Smart Lightning app, it has the ability turn off switches after turning them on.
True, the app doesn’t work well on older devices with less than 2GB RAM. For example on the iPhone 6s or 7 it takes upto 30 seconds before devices are available to use. However on the iPhone 12 Pro, it’s ready in under 3 seconds. I think ST mentioned this somewhere, new app works faster with more RAM.
I totally understand your frustrations (I’ve been with ST for 7 years and gone through all kinds of pains), but every system has their own issues, nothing’s perfect or even close to it. The thing I personally like about ST is the community and alternative options available (e.g. if Scenes don’t work, you have Automations or Smart Lightning or WebCoRE or custom SmartApps). Hope you find this helpful.
