GRClark
(Gene Clark)
January 20, 2018, 10:02pm
1
Does anyone know if these plugs
will work with this device handler?
April 26, 2018. Added support for the HS220 Dimming Switch.
January 30, 2018. Update to Version 2. Changes
a. Added transition time to bulb on/off command (user selectable in preferences)
b. Fixed Energy Monitor to accommodate HS110(AU) data formats.
c. Commonized menus between Hub and Cloud versions.
d. Updated naming conventions to function based, supporting TP-Link’s expanding product line.
e. Changed naming conventions to support GitHub integration.
Upgrade Recommendation: Do not recommend upgrade unless you need to add device models not in previous baseline.
Verification Status:
HS100, HS105, HS200 - verified on exact device.
HS110 - previous version verified by other users.
HS115 - future product, same control as HS110.
KP100 - assumed same control as HS100.
HS2…
I’d like to use the cloud option.
Gutheinz
(Dave Gutheinz)
January 20, 2018, 10:19pm
2
I just updated the Service Manager to install the KP100 as a HS Series Plug. Should work if installed using instructions. IF NOT, please tell me and give error report.
Dave
PS - The KP100 is a new part number. Believe it is (functionally) a HS105 built for K-Mart or as the new series nomenclature. Commands should be the same.
