Welcome to the SmartThings Community, @Cyan!
Where are you seeing this error, can you share the link, please?
oh, that’s strange I didn’t recognize the page without the scope list.
I can open it correctly, so, it might be something on your side or account…
Can you clear the browser’s cache and try again, please?
If it is still happening, can you open the developer tools in the browser to see if you get an error there?
Welcome to the SmartThings Community, @Y0lk!
Can you share the following info so I can create a report for the engineering team, please?
- Screenshot of the issue (the page without the scope list). The one with the errors you shared is useful.
- Confirm if the email you use here in the forum is the same as in your ST account. If not, please send it over a DM.
- Enable support access to your account
- Go to the SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
Hi, @Y0lk
Thanks for the info.
Following up, the engineering team mentioned if you could share the timeframe or timestamp when the error happened. For example “08:20 CST”
Also, does this happen every time you enter this page even if you refresh it?
Yes, this happens every time. I have not been able to create a new access token because of this issue.
I just tried again to get you a time stamp: “11:21 EST”
Hi,
I just tried again and I still have the same problem. I’ve tried clearing my cache again as well but it didn’t change anything. I still have the same issue where I don’t see any scopes.
The team found the error, they mentioned it will solved later on, there’s no ETA yet.
However, they provided this workaround for you to be able to create a PAT while the issue is being solved. You can set your locale to en-US using sensors for Chrome
Example:
Thanks for the temporary solution! I can confirm that overriding the locale worked.
Did this ever get fixed I am still having this problem. I tried changing the locale but still no authorized scopes appear
Hi, @fourtrax01. Welcome to the SmartThings Community!
This issue should be solved now, and as the workaround doesn’t work for you, it might be due to something else.
Can you re-load the page and share a screenshot of the page to see how the scopes are missing and also open the developer console where the locale is shown to see the default value it assigns just in case, please?
- Go to the SmartThings Web (my.smartthings.com )
