Is there a way to turn on a switch when temp is above x, and turn off when temp is below y? I have a vent fan in a closet I would like to turn on automatically based on temperature. Thanks
There may be some specialized apps out there. CoRE can do that too, using a latching piston - it was designed with histeresys in mind
IF
Sensor temperature is greater than 80 degrees
THEN
Using switch...
> Turn on
BUT IF
Sensor temperature is less than 75
THEN
Using switch...
> Turn off
If you need the same tempearature threshold for on and off, then a Simple piston is enough:
IF
THEN
Using switch...
> Turn on
ELSE
Using switch...
> Turn off
There is a thread for assistance with CoRE if you go the dark CoRE path and need more help.
There is a thermostat app - called Virtual Thermostat.
Search the forum for it as not sure where I found it. I’m using a motion sensor’s temp. reading to turn on/off a fan i my garage.
Can you confirm it works with an on/off switch? In the settings I just see outlet. Thanks
They share the same capability (Switch) so outlet or switch, same thing. Give it a try
I think one of the keep me cozy apps would do this. I recommend an app for this, unless you like logic.
