I have a simple “Good Night” routine set up to trigger when “things quite down” between 11:45pm and 3:20am and change the mode to Arm (Stay). The trigger is set “when there is no motion on any” of these 3 sensors…Family Room, Living Room and Kitchen for 25 minutes. The trigger seems to fire if any one of the sensors shows no movement. What I would like to have is a check to see if there is any movement on any of the sensors and not to go to sleep mode until all three are quiet for 25 minutes. TIA
Well if you don’t mind getting a little dirty, you could use this app to combine all your sensors into one virtual zone with it’s own timeout setting.
