There is a critical CoRE update available - How do I do it?
Hello,
I have fallen out of the loop over the last year. Can you help me get back to speed?
First off, there is a ‘Critical CoRE update available’ I can seem to figure out how to update. Can someone explain?
Also, what is webCoRE? does it replace CoRE? Do I skip the CoRE update and get webCoRE? Can someone tell me how to get webCoRE?
I only have 3 small CoRE pistons that could be fairly eaisly rebuilt if necessary.
Thank You- Jim
Use WebCoRE then.
They have a separate forum now since it got too big for this one.
Checkout:
http://thingsthataresmart.wiki/index.php?title=CoRE
…and…
I used to use CoRE as well, and recently switched to webCoRE. If your needs are simple, and you’re already using CoRE, my opinion: just stay with what you’re using (albeit the latest & greatest version.) webCoRE is much easier to use and way more powerful, but again, depends on your needs.
Agreed with all the above. If you only have 3 pistons in CoRE, your move to WebCoRE should be simple. CoRE is dead, WeCoRE replaces it and is much more powerful.
