IFTTT + CoRE/ST will do the trick. Enable expert mode in CoRE. Create a piston in CoRE with IFTTT as trigger (you’ll need to figure out the dashboard URI and use it in IFTTT’s Maker channel). Scroll down to Import event data into variables. Make sure in IFTTT to send the ingredient over through the Maker channel. Then in CoRE just select the Sonos speaker and have it playText {ingredientName} from IFTTT. Use { } around the variable name to have the variable replaced for its value.
