Tendril OTL-8 ZigBee Smart Plug
Has anyone had any luck getting the Tendril OTL-8 ZigBee Smart Plug to work with Smartthings. I purchased this for a cheap repeater but I haven’t had any looking getting it to work. This is the only documentation I have been able to find.
This is a ZigBee Smart Energy device and is not compatible with SmartThings. I assume you’ve already tried pairing it and changing the Device Type Handler? If it doesn’t work with SmartPower Outlet you’ll probably need some custom code.
Thanks, I haven’t even had any luck getting it to pair.
That’s using the SE profile. I doubt if it will work with SmartThings, but you can try.
