Sync garage door
I tried to set up a CoRE piston to sync my garage tilt sensor with a virtual door and it worked well for automated changes. I was never able to get the physical switch sync working because the time difference between opening the door and the sensor actually showing it was not consistent and the garage door would always stop half way open or closed. I am sure there is a right way though… well here is my automated piston (should be easy to adapt for 2 doors).
