I am trying to create a SmartApp that is essentially a combination of ‘The Big Switch’ and ‘Double Tap’. The behavior I am looking for is:
On single press do X
On double press do Y; but NOT X
Obviously the first press always falls through initially, so a double press does X and Y. I have tried putting a ‘pause’ in the event handler to wait for the second press (if present), but that seems to block any additional events.
How can I look for a double press first? and if not present, then execute X.
It seems ‘runIn’ won’t actually set a schedule unless it is set for 60 seconds or more. Really don’t want to have to wait a whole minute for X to be executed via a single press.
So, what you want is a delay after first press to wait xx seconds before firing first press command but if 2nd press occurs within xx seconds then first only double press?
What I would do is something like this:
On first press, log the datetime of first press
start a timer for xx seconds
On second press, check if datetime of this press is within xx time of first press datetime
if yes, fire double press event, set var for double press = true
On end of timer, check for double press == true
if not, then fire single press event.
Or, just get last two events from button press, compare times and do one or the other based on time difference
Looking at the canned DoubleTap app, it looks like when it sees an “on” tap, it looks in the log for the device to see if there’s been recent activity and if there’s two “on” taps within the recently time allowed then it acts on the double tap instructions.
It might be possible to do the same thing but look for NO additional press within the time allotted.
I get an error whenever I try to use any interation of unschedule(). It seems like this is a job for the java.util.timer, but for some reason creating an instance of that is not allowed.
This worked… albeit I haven’t used it in quite some time. Seems SmartThings broke a lot of things in the recent platform update. What you’re seeing may be due to one of them.
My problem was trying to use those functions in a device type. Device types are even more limited than apps, and there do not seem to be any delay or timer functions whatsoever.
