Philips released a firmware a few weeks back that would prevent non-Philips bulbs from pairing. They subsequently rolled that part of the firmware back after customer complaints. They may be trying to prevent these knockoffs from pairing still. Maybe they can’t distinguish the color bulb from their own.
Kudled just released a USD$20 RGBW 9W bulb, just ordered, let’s see how it goes.
A question on the endpointId - Can we do ? (sorry, I’m new to ST / Groovy programming)
How do we know whether is kudled or others? profile id?
if (kudled) {
return 0x0B
} else {
return ${endpointId}
You guys are awesome! thanks for Scott’s tip! it really help, I managed to make the Kudled color bulb work with ST hub by replacing all ${endpointid} to 0x0B in Zigbee Hue Bulb device handler. I’m now able to control on/off, changing color and brightness!
Do you have a link? Thx
It’s in Chinese, no English product details.
They have not list/launch the bulbs. I contacted them via Taobao.
English site
Thx for the links. Hope you can get this working. At $20 that’s a steal.
Hi @Kelvin_Kueh, do you mind sharing your code, for some reason I get below error when using the Zigbee Hue Bulb device handler. Thanks in advance.
Java.lang.IllegalArgumentException: Metadata definition not found
Hi Joe
Below is the Kudled color bulb device handler code
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
/* Kudled (via Zigbee)
Capabilities:
Actuator
Color Control
Configuration
Polling
Refresh
Sensor
Switch
Switch Level
Custom Commands:
setAdjustedColor
metadata {
definition (name: "Kudled Color Bulb", namespace: "KelvinKueh", author: "Kelvin.kueh@gmail.com") {
capability "Switch Level"
capability "Actuator"
capability "Color Control"
capability "Switch"
capability "Configuration"
capability "Polling"
capability "Refresh"
capability "Sensor"
command "setAdjustedColor"
fingerprint profileId: "C05E", inClusters: "0000,0003,0004,0005,0006,0008,0300,1000", outClusters: "0019"
// simulator metadata
simulator {
// status messages
status "on": "on/off: 1"
status "off": "on/off: 0"
// reply messages
reply "zcl on-off on": "on/off: 1"
reply "zcl on-off off": "on/off: 0"
// UI tile definitions
tiles {
standardTile("switch", "device.switch", width: 1, height: 1, canChangeIcon: true) {
state "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
state "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
state "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
controlTile("rgbSelector", "device.color", "color", height: 3, width: 3, inactiveLabel: false) {
state "color", action:"setAdjustedColor"
controlTile("levelSliderControl", "device.level", "slider", height: 1, width: 2, inactiveLabel: false) {
state "level", action:"switch level.setLevel"
valueTile("level", "device.level", inactiveLabel: false, decoration: "flat") {
state "level", label: 'Level ${currentValue}%'
controlTile("saturationSliderControl", "device.saturation", "slider", height: 1, width: 2, inactiveLabel: false) {
state "saturation", action:"color control.setSaturation"
valueTile("saturation", "device.saturation", inactiveLabel: false, decoration: "flat") {
state "saturation", label: 'Sat ${currentValue} '
controlTile("hueSliderControl", "device.hue", "slider", height: 1, width: 2, inactiveLabel: false) {
state "hue", action:"color control.setHue"
main(["switch"])
details(["switch", "levelSliderControl", "rgbSelector", "refresh"])
// Parse incoming device messages to generate events
//log.trace description
if (description?.startsWith("catchall:")) {
def msg = zigbee.parse(description)
//log.trace msg
//log.trace "data: $msg.data"
else {
def name = description?.startsWith("on/off: ") ? "switch" : null
def value = name == "switch" ? (description?.endsWith(" 1") ? "on" : "off") : null
def result = createEvent(name: name, value: value)
log.debug "Parse returned ${result?.descriptionText}"
return result
def on() {
// just assume it works for now
log.debug "on()"
sendEvent(name: "switch", value: "on")
"st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}"
def off() {
log.debug "off()"
sendEvent(name: "switch", value: "off")
"st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}"
def setHue(value) {
def max = 0xfe
log.trace "setHue($value)"
sendEvent(name: "hue", value: value)
def scaledValue = Math.round(value * max / 100.0)
def cmd = "st cmd 0x${device.deviceNetworkId} 0x0B 0x300 0x00 {${hex(scaledValue)} 00 0000}"
//log.info cmd
cmd
def setAdjustedColor(value) {
log.debug "setAdjustedColor: ${value}"
def adjusted = value + [:]
adjusted.hue = adjustOutgoingHue(value.hue)
adjusted.level = null // needed because color picker always sends 100
setColor(adjusted)
def setColor(value){
log.trace "setColor($value)"
def max = 0xfe
sendEvent(name: "hue", value: value.hue)
sendEvent(name: "saturation", value: value.saturation)
def scaledHueValue = Math.round(value.hue * max / 100.0)
def scaledSatValue = Math.round(value.saturation * max / 100.0)
def cmd = []
if (value.switch != "off" && device.latestValue("switch") == "off") {
cmd << "st cmd 0x${device.deviceNetworkId} 0x0B 6 1 {}"
cmd << "delay 150"
cmd << "st cmd 0x${device.deviceNetworkId} 0x0B 0x300 0x00 {${hex(scaledHueValue)} 00 0000}"
cmd << "delay 150"
cmd << "st cmd 0x${device.deviceNetworkId} 0x0B 0x300 0x03 {${hex(scaledSatValue)} 0000}"
if (value.level != null) {
cmd << "delay 150"
cmd.addAll(setLevel(value.level))
if (value.switch == "off") {
cmd << "delay 150"
cmd << off()
log.info cmd
cmd
def setSaturation(value) {
def max = 0xfe
log.trace "setSaturation($value)"
sendEvent(name: "saturation", value: value)
def cmd = "st cmd 0x${device.deviceNetworkId} 0x0B 0x300 0x03 {${hex(scaledValue)} 0000}"
//log.info cmd
cmd
def refresh() {
"st rattr 0x${device.deviceNetworkId} 1 6 0"
def poll(){
log.debug "Poll is calling refresh"
refresh()
def setLevel(value) {
log.trace "setLevel($value)"
def cmds = []
if (value == 0) {
cmds << "st cmd 0x${device.deviceNetworkId} 0x0B 6 0 {}"
else if (device.latestValue("switch") == "off") {
sendEvent(name: "level", value: value)
def level = hexString(Math.round(value * 255/100))
cmds < 31) {
if (percent < 63.0) {
adjusted = percent + (7 * (percent -30 ) / 32)
else if (percent < 73.0) {
adjusted = 69 + (5 * (percent - 62) / 10)
else {
adjusted = percent + (2 * (100 - percent) / 28)
log.info "percent: $percent, adjusted: $adjusted"
adjusted
Awesome! Thanks @Kelvin_Kueh, I let you know when it works out
looking to get their zigbee wall switch next. To control the non smart ceiling lamps.
Pulling in a neutral will be a PITA tho. Will get an electrician to do the job
Not sure how it will work out.
The $20 Kudled RGBW 9W bulb is able to pair with Philips hue bridge as extended color light !!
Are these bulbs available in the states yet?
Can you share what you have to do to get the bulb to pair with the hue bridge?
It’s the same way you pair with hue bulb.
I am having trouble with pairing the RGB kunled bulb with either the hue bridge v1 or the smartthings v2 hub.
The bulb flashes red, green, blue, then back to red and repeat when power is applied. Does this indicate that the bulb is in paring mode?
No device was found when I tried to pair.
Thanks in advance,
Johnny
Try resetting the bulb, on/off, on/off, on/off, and it flashes a few times, then start detection.
I’m using hue bridge v2, ST v2, no issue with RGB.
@jakers102: My team just got off the phone with Kudled representatives and now we are being informed that the latest generation Kudled bulbs are compatible by default with the Philips Hue Bridges.
Background story:
I had bought a few Kudled bulbs in August 2015 and they were compatible with the Philips Hue Bridge 1.0, resulting in this original topic creation.
Then in November 2015 I had bought another batch of Kudled bulbs and they were NOT compatible with the Philips Hue Bridge 1.0.
We had connected with Kudled to ask for feedback and they indicated they were in discussions with Philips and were not allowed to produce compatible bulbs at the time.
Now (March 2016) they have informed us they are producing Kudled bulbs again which are by default compatible with Philips Hue Bridges 1.0 and 2.0…
As the ZigBee protocol is open, Kudled is to my understanding allowed to make bulbs which use the same frequency as original Philips Hue Bulbs, however Philips can still theoretically block syncing / pairing via their App and I believe Philips officially created a Friends of Hue program to properly integrate non-Hue bulbs with the Philips Hue Bridges.
Conclusion:
I think, but I am not sure that you @jakers102 may have a Kudled bulb from an older batch whereas @hongtat may have a Kudled bulb from a new batch…
Thanks for the insight , Chun.
I am guessing there is no obvious way to tell if a kudled bulb is from the old or new batch. And am I safe to assume when the bulb is flashing red, green, blue, that the bulb is in paring mode already?
Johnny
Yes, when you turn the bulb on/off quickly several times it will go into the flashing red, green, blue mode which is it’s pairing mode, at least from my personal experience and I believe hongtat indicated the same.
