I have a VeraEdge and I want to keep (A lot of routine and program) but I want to use the interface of TS more WAF and the compatibility with Harmony Logitech Hub.
Do you know if is possible to use TS like a Slave and keep Vera like a Master.
The Vera interface to devellop and TS interface to use.
If by “TS” you mean SmartThings, it’s technically possible to add SmartThings as a zwave secondary controller, But support now says that is “strongly discouraged.” And it probably won’t work the way you expect.
In particular, the statuses will be out of sync, so that vera won’t know when SmartThings turned something on and SmartThings won’t know when vera turned something on. That can mess up programming on both sides.
