Hey @TAustin really appreciate your hard work with this as I’ve created a lot of virtual devices using your driver…for several months now, so many thanks!
However, two nights ago, I rebooted my SmartThings V.3 hub, and when it came back online, none of the virtual devices that I created with the vEdge Creator were responding.
I have several device types using the V2 driver and they all are inoperable right now. When turning on/activating any of these virtual devices the button will rotate for about 5 seconds, then an error: “A network or server error occurred. Try again later.”
When I try to create a new virtual device using the generator, it will time out after ~5 seconds with the same error as above.
What is interesting is that I still had the v1 drivers installed, so when I change a device from v2 to v1, the device works again.
I can also use the v1 Generator to create a new virtual device, which works (using the old driver), so then I change the v1 device to the v2 driver, and it stops working again.
What is also interesting is that there are NO logs created for the above issues when they occur in the IDE or in the ST app.
I also have several virtual edge devices that use ygerlovin’s drivers with no issues.
I’m assuming I could change all the v2 devices to the v1 driver, then reinstall the v2 drivers and then switch all the devices back to v2? I have SO many drives with complicated routines, that it scares me to uninstall the associated driver – as I believe that would uninstall all the devices using that driver, is that correct?
What are your thoughts?
Here’s the hub’s info:
Hub Firmware version: 000.042.00007
Hub Hardware version: Hub v3 US
Zigbee:
- State: Functional
- Version: 5.4.0
- EUI: 286D970002003681
- Channel: 14
- Node ID: 0000
- Pan ID: 82C0
- OTA: enabled for all devices
- Unsecure Rejoin: true
Zwave:
- State: Functional
- Home ID: D6916F2A
- Node ID: 01
- Suc ID: 01
- Protocol Version: 6.04
- Region: US
