panasonic-climacontrol-lan is an Edge LAN driver for Panasonic split-system air conditioners fitted with ProtoART’s ClimateControl Wi-Fi module for Panasonic (PANA_CNCNT_ATA_WIFI). The module plugs into the indoor unit’s CN-CNT connector, and the driver talks to it directly over its local HTTP API. There’s no Panasonic Comfort Cloud account, no bridge server and no internet dependency.
ProtoART: product · HTTP API · manual
What you get
One device per module (one per indoor unit):
- Power, Mode (Auto, Cool, Dry, Fan Only, Heat) and Fan Speed (Auto, Quiet, Low, Medium, High, Turbo). Choosing a mode while the unit is off also switches it on (optional).
- Set Temperature in 0.5 °C steps, within the range the module reports, plus room temperature.
- Presets (Quiet, Normal, Powerful), Vane Up/Down (Highest, Middle, Normal, Low, Lowest, Swing, Auto) and Vane Left/Right (Maximum Left, Left, Middle, Right, Maximum Right, Auto), named as on the module’s own page.
- Eco, Eco Navi, nanoe X and Mild Dry switches, shown only for the features your unit has. Set this with Unit features (see Settings), and the driver also learns it: a switch your unit turns back off twice is hidden on that unit, and the same goes for Vane Left/Right and Heat.
- Power use (W) and outdoor temperature, when the unit reports them.
- Wireless Thermometer: whenever ProtoART’s wireless thermometer is paired to the module, its temperature, humidity and battery appear in their own section.
- Windows/Doors: with ProtoART’s window/door sensors paired (up to 4 per module), the air conditioner shows one combined contact (open if any is open) with the lowest battery. Each sensor also becomes its own contact-sensor device (open/closed, battery), so you can give it its own room and use it in Routines, SmartThings Home Monitor and Alexa.
- Module diagnostics: indoor unit link, which temperature sensor the AC is using (Internal, Wireless or External), the module’s room temperature guard, Wi-Fi signal, IP and MAC address, firmware (and whether an update is available), uptime, plus a Restart module button.
- Everything is available in Routines.
Settings (device ⋮ → Settings)
- Module Password: only if the module has a web password set. The driver logs in like the module’s own web page does.
- Cooling only: leaves Heat out of the modes for cooling-only units.
- Unit features: All extras / nanoe X models / Eco Navi models / Basic. The module can’t tell which extras your indoor unit has, so this hides the switches it doesn’t have. Changing it also brings back anything the driver hid by itself.
- Room guard, lowest and highest (5–40 °C): the module’s temperature guard, which switches the unit on if the room gets too cold or too warm while it’s off. Left at “Leave as set on the module”, the driver never changes it. On a cooling-only unit, set the lowest to 5 °C so the guard never tries to heat.
- IP Address (only if discovery can’t reach the module), Poll Interval (5–300 s, default 15) and Mode change turns the unit on.
How it works
- Discovery: each web server found by mDNS is asked for its status, so modules are recognised by their answer, whatever they’re named. Each module is then identified by its MAC address: scanning again never duplicates a device, and a module that changes IP is found again. A password set on one module’s device is tried on new modules, but only on servers whose login page is a ClimateControl one. Modules for other air conditioner brands are skipped.
- Status: polled every 15 s by default. Only changed values are sent to SmartThings.
- Commands: ProtoART’s documented
/controlcommands. The status is then read every 5 s for a minute, so a setting your unit doesn’t accept shows its real value again within seconds. - A module that stops answering (e.g. the air conditioner is switched off at the isolator) goes offline after 3 failed polls, along with its sensor devices, and is looked for on the network every 5 minutes until it’s back.
- A sensor unpaired from the module: its device goes offline instead of keeping its last state. A sensor device you delete stays deleted; Scan for nearby devices brings it back.
Setup
- Connect each module to your 2.4 GHz Wi-Fi (WPS, or its own access point; see ProtoART’s manual). A DHCP reservation for each module is a good idea.
- Accept the channel invite and install panasonic-climacontrol-lan: SmartThings. Add a little smartness to your things.
- Add device → Scan for nearby devices. One device appears per module, named from the module’s web page (or “Panasonic AC” plus the end of its MAC address). If the module has a web password, enter it in the device’s Settings. If no module is found, a single “Panasonic AC” device appears: enter the module’s IP address in its settings.
- Set Cooling only and Unit features to match your indoor unit.
Good to know
- The thermometer and window/door sensors are the Bluetooth sensors ProtoART sells for the module (the window/door sensor is a MOES ZSS-GWM-C, likely with ProtoART firmware), paired to the module on its web page. SmartThings sees them through the module.
- A unit that doesn’t support a setting puts it back by itself, usually within 10–30 s. The driver only learns from this while the unit is on and no window is open, hides a setting only after it’s been put back twice, and clears the count when a setting holds for a minute, so a feature that’s only occasionally cancelled stays. A command that fails (e.g. a Wi-Fi drop-out) never counts, and a check is dropped if another setting changes meanwhile (a preset, the fan, the mode, or the remote).
- Some older units silently accept a feature they don’t have (e.g. Eco Navi) and never put it back, so learning can’t catch it: set Unit features for those. Some older units also don’t report power or room temperature; those tiles then show 0 W or a fixed value.
- While a window or door is open, the module’s window function pauses the unit and overrides its settings (e.g. fan speed) until it’s closed.
- The module allows one web login at a time. Logging in on its web page briefly logs the hub out; the driver logs back in automatically.
- If Temperature Input stays “Internal” with a wireless thermometer paired, the module couldn’t calibrate it. That’s usually the CN-TH cable: Panasonic units use 4-pin or 6-pin cables. ProtoART can advise which one your unit needs.
- The SmartThings app shows the Module Password in plain text on the Settings page.
Not included: the module’s remote room-temperature input. It needs a reading resent every 5 seconds.
If the driver’s useful to you, you can support its development through GitHub Sponsors ![]()
Driver version:
2026-11-21T00:24:51.550069835
