[ST Edge LAN Driver] Hunter Pacific DC ceiling fans (Tuya WiFi, local control)
Hunter Pacific DC ceiling fans with a Tuya WiFi module, controlled locally from SmartThings
This is an Edge driver for Hunter Pacific DC fans that pair with the Smart Life / Tuya app. I tested it on an Aqua DC. It talks to the fan over your home network using Tuya’s local protocol, so once it’s set up, nothing goes through the cloud.
Features
  • Fan on/off, speed Off + 1–9 (matches the 9-LED remote) and direction.
  • Optional light kit: on/off and brightness, as its own SmartThings device so Alexa and Google see it.
  • Multiple fans, with an Add another fan button.
  • Commands are retried and checked against the fan’s reported state.
  • The fan shows offline if its local key or device ID is wrong, or if it can’t be reached for 3 polls in a row.
  • All values can be used in Routines.
Install
  1. Accept the channel invite and enrol your hub: SmartThings. Add a little smartness to your things.
  2. Under Available Drivers, install hunterpacific-tuya-lan.
  3. Get each fan’s local key, device ID and LAN IP. tinytuya does this: pip install tinytuya, then python -m tinytuya wizard. Use the IP from your router, not the ip from Tuya’s cloud (that’s your internet address).
  4. In the SmartThings app, go to Add device → Scan for nearby devices. Then open the new fan’s Settings and enter the IP, local key and device ID. Paste the key rather than typing it, because phone keyboards can swap in curly quotes or dashes.
  5. For more fans, press Add another fan on the first one.
Things to know
  • Light kit: the fan’s WiFi module reports a light whether or not one is fitted (that’s why the Tuya app shows a light switch on fans without one). So the light is off by default. Turn on Light Kit Fitted in the fan’s settings if you have one. I’ve asked Hunter Pacific whether a module update could detect it.
  • Reversing: the fan slows, stops and reverses on its own. It ignores another direction change for about 30 seconds while it’s reversing, so the driver keeps retrying until it takes.
  • If the speed slider doesn’t show Off + 1–9 after an update, close and reopen the SmartThings app.
  • The fan accepts one local connection at a time, so another local integration (e.g. Home Assistant) talking to the same fan can collide with the driver.
Source: smartthings-drivers/hunterpacific-driver at main · ST-SmartHome/smartthings-drivers · GitHub
The driver shares its Tuya code with my Ventair Skyfan DC driver. If you have another Hunter Pacific model with a Tuya module, I’d like to hear whether it works. Feedback and logs are welcome here.
Driver version: 2026-10-10T05:02:22.217504864
If the driver’s useful to you, you can support its development through GitHub Sponsors :heart:
