I think this driver will work but I’m not very good with the CLI to upload it.
This is the driver configuration.
You can modify these settings to match your needs.
local driver_name = “MOES Tuya ZigBee Smart IR Remote Control”
local device_id = “moes-tuya-zigbee-smart-ir-remote-control”
local device_type = “zigbee”
local device_manufacturer = “MOES”
local device_model = “Tuya ZigBee Smart IR Remote Control”
local device_fingerprint = {
manufacturer = “MOES”,
model = “Tuya ZigBee Smart IR Remote Control”,
fingerprint = “0x0102030405060708090A0B0C0D0E0F”
This is the driver code.
This code handles the communication between SmartThings and the MOES Tuya ZigBee Smart IR Remote Control.
local driver = {}
function driver.on_initialize()
– Initialize the driver.
log.info(“Initializing driver…”)
– Connect to the MOES Tuya ZigBee Smart IR Remote Control.
local device = zigbee.connect(device_id)
if device == nil then
log.error("Failed to connect to device.") returnend
– Set the device name.
device:set_name(driver_name)
– Set the device type.
device:set_type(device_type)
– Set the device manufacturer.
device:set_manufacturer(device_manufacturer)
– Set the device model.
device:set_model(device_model)
– Register for events.
device:register_event(“on_button_press”)
device:register_event(“on_button_release”)
log.info(“Driver initialized.”)
end
function driver.on_button_press(event)
– Handle a button press event.
log.info("Button pressed: " … event.button)
– Send a command to the MOES Tuya ZigBee Smart IR Remote Control.
device:send_command(event.button)
end
function driver.on_button_release(event)
– Handle a button release event.
log.info("Button released: " … event.button)
end
return driver
