[ST Edge] Breaking boundaries: supporting Blue Iris motion alerts and Shelly wifi Motion Sensors
Just want to say thanks for this. Finally got around to updating my blue iris motion integrations since they stopped working a few months ago and it’s awesome you’ve created something that works locally! I struggled a bit with getting python working on my windows 7 machine but eventually figured it out.
That’s great. Glad it’s meeting your needs. :+1:t3:
I’ll echo the sentiment (again). @TAustin , you really created something fantastic for Blue Iris users. I have a motion sensor just for packages. I have another for when people are in my driveway vs just vehicles. The response times shows up on par with Zwave sensors in the same area.
Thanks again for keeping this integration alive with the transition.
I cannot seem to get the LAN Device Name in Smartthings to change and save. Any thoughts?
@TAustin , Having trouble getting the LAN Device to connect to the server. I have changed the LAN Device Name to Match Cam4 from the HTTP request. LAN Device Address is xxx.xxx.xx.x8 and Bridge Address is xxx.xxx.xx.x8:8088.
Blue Iris seems to send the motion test as shown in the first image. However, getting an invalid endpoint in EdgeBridge and No Stream 400 error in Blue Iris. I see no registration showing up in the EdgeBridge Folder on the PC either (believe I should once new device is created but could be wrong).
In SmartThings, the Cam4 device I created shows as Offline, which I also assume means it hasn’t registered with EdgeBridge. I have rebooted both my hub, and PC that runs BI/EdgeBridge but have same results. Must be missing something but not sure what.
This was being discussed in an Edgebridge thread on IPCamTalk
Cause: The Windows Defender Firewall was blocking access from the ST hub to the PC running the Edgebridge server.
Yup that was me. Guy helped me out and I am up and running. Thanks for posting here before I got to it. Excellent so far.
