Speaker Companion Different sounds?
Does anyone know if there’s a way to use custom sounds or if there are any more sounds available to use with the speaker companion app? Or is there an alternative to speaker companion where I can have my sonos speakers make different sounds based on certain sensor states (motion, open, etc).
Great question! You can edit the smart app code and change the url in the code to a url that plays a different sound.
http://soundbible.com/grab.php?id=2154&type=mp3
did you get it going? You may need a custom smart app for speaker companion. I don’t think you can edit the speaker companion smart app from the regular ST app marketplace. I have a copy of the community app if you need it.
Do you have a copy of the full Speaker Companion smartapp? I don’t see it in the community repo. It seems that the Speaker Companion is a combination of the Speaker Notify, Speaker Control, and Speaker Weather Forecast Apps. Just curious if there were any updates when they were combined.
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
 *  Speaker Custom Message
 *  Author: SmartThings
 *  Date: 2014-1-29
definition(
	name: "Speaker Notify with Sound",
	namespace: "smartthings",
	author: "SmartThings",
	description: "Play a sound or custom message through your Speaker when the mode changes or other events occur.",
	category: "SmartThings Labs",
	iconUrl: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos.png",
	iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Partner/sonos@2x.png"
preferences {
	page(name: "mainPage", title: "Play a message on your Speaker when something happens", install: true, uninstall: true)
	page(name: "chooseTrack", title: "Select a song or station")
	page(name: "timeIntervalInput", title: "Only during a certain time") {
		section {
			input "starting", "time", title: "Starting", required: false
			input "ending", "time", title: "Ending", required: false
def mainPage() {
	dynamicPage(name: "mainPage") {
		def anythingSet = anythingSet()
		if (anythingSet) {
			section("Play message when"){
				ifSet "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
				ifSet "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
				ifSet "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
				ifSet "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
				ifSet "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
				ifSet "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
				ifSet "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
				ifSet "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
				ifSet "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
				ifSet "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
				ifSet "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
				ifSet "triggerModes", "mode", title: "System Changes Mode", required: false, multiple: true
				ifSet "timeOfDay", "time", title: "At a Scheduled Time", required: false
		def hideable = anythingSet || app.installationState == "COMPLETE"
		def sectionTitle = anythingSet ? "Select additional triggers" : "Play message when..."
		section(sectionTitle, hideable: hideable, hidden: true){
			ifUnset "motion", "capability.motionSensor", title: "Motion Here", required: false, multiple: true
			ifUnset "contact", "capability.contactSensor", title: "Contact Opens", required: false, multiple: true
			ifUnset "contactClosed", "capability.contactSensor", title: "Contact Closes", required: false, multiple: true
			ifUnset "acceleration", "capability.accelerationSensor", title: "Acceleration Detected", required: false, multiple: true
			ifUnset "mySwitch", "capability.switch", title: "Switch Turned On", required: false, multiple: true
			ifUnset "mySwitchOff", "capability.switch", title: "Switch Turned Off", required: false, multiple: true
			ifUnset "arrivalPresence", "capability.presenceSensor", title: "Arrival Of", required: false, multiple: true
			ifUnset "departurePresence", "capability.presenceSensor", title: "Departure Of", required: false, multiple: true
			ifUnset "smoke", "capability.smokeDetector", title: "Smoke Detected", required: false, multiple: true
			ifUnset "water", "capability.waterSensor", title: "Water Sensor Wet", required: false, multiple: true
			ifUnset "button1", "capability.button", title: "Button Press", required:false, multiple:true //remove from production
			ifUnset "triggerModes", "mode", title: "System Changes Mode", description: "Select mode(s)", required: false, multiple: true
			ifUnset "timeOfDay", "time", title: "At a Scheduled Time", required: false
		section{
			input "actionType", "enum", title: "Action?", required: true, defaultValue: "Bell 1", options: [
				"Custom Message",
				"Bell 1",
				"Bell 2",
				"Dogs Barking",
				"Fire Alarm",
				"Matts Custom Airplane Ding",
				"A door opened",
				"There is motion",
				"Smartthings detected a flood",
				"Smartthings detected smoke",
				"Someone is arriving",
				"Piano",
				"Lightsaber"]
			input "message","text",title:"Play this message", required:false, multiple: false
		section {
			input "sonos", "capability.musicPlayer", title: "On this Speaker player", required: true
		section("More options", hideable: true, hidden: true) {
			input "resumePlaying", "bool", title: "Resume currently playing music after notification", required: false, defaultValue: true
			href "chooseTrack", title: "Or play this music or radio station", description: song ? state.selectedSong?.station : "Tap to set", state: song ? "complete" : "incomplete"
			input "volume", "number", title: "Temporarily change volume", description: "0-100%", required: false
			input "frequency", "decimal", title: "Minimum time between actions (defaults to every event)", description: "Minutes", required: false
			href "timeIntervalInput", title: "Only during a certain time", description: timeLabel ?: "Tap to set", state: timeLabel ? "complete" : "incomplete"
			input "days", "enum", title: "Only on certain days of the week", multiple: true, required: false,
				options: ["Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"]
			if (settings.modes) {
            	input "modes", "mode", title: "Only when mode is", multiple: true, required: false
			input "oncePerDay", "bool", title: "Only once per day", required: false, defaultValue: false
		section([mobileOnly:true]) {
			label title: "Assign a name", required: false
			mode title: "Set for specific mode(s)", required: false
def chooseTrack() {
	dynamicPage(name: "chooseTrack") {
		section{
			input "song","enum",title:"Play this track", required:true, multiple: false, options: songOptions()
private songOptions() {
	// Make sure current selection is in the set
	def options = new LinkedHashSet()
	if (state.selectedSong?.station) {
		options << state.selectedSong.station
	else if (state.selectedSong?.description) {
		// TODO - Remove eventually? 'description' for backward compatibility
		options << state.selectedSong.description
	// Query for recent tracks
	def states = sonos.statesSince("trackData", new Date(0), [max:30])
	def dataMaps = states.collect{it.jsonValue}
	options.addAll(dataMaps.collect{it.station})
	log.trace "${options.size()} songs in list"
	options.take(20) as List
private saveSelectedSong() {
	try {
		def thisSong = song
		log.info "Looking for $thisSong"
		def songs = sonos.statesSince("trackData", new Date(0), [max:30]).collect{it.jsonValue}
		log.info "Searching ${songs.size()} records"
		def data = songs.find {s -> s.station == thisSong}
		log.info "Found ${data?.station}"
		if (data) {
			state.selectedSong = data
			log.debug "Selected song = $state.selectedSong"
		else if (song == state.selectedSong?.station) {
			log.debug "Selected existing entry '$song', which is no longer in the last 20 list"
		else {
			log.warn "Selected song '$song' not found"
	catch (Throwable t) {
		log.error t
private anythingSet() {
	for (name in ["motion","contact","contactClosed","acceleration","mySwitch","mySwitchOff","arrivalPresence","departurePresence","smoke","water","button1","timeOfDay","triggerModes","timeOfDay"]) {
		if (settings[name]) {
			return true
	return false
private ifUnset(Map options, String name, String capability) {
	if (!settings[name]) {
		input(options, name, capability)
private ifSet(Map options, String name, String capability) {
def installed() {
	log.debug "Installed with settings: ${settings}"
	subscribeToEvents()
def updated() {
	log.debug "Updated with settings: ${settings}"
	unsubscribe()
	unschedule()
	subscribeToEvents()
def subscribeToEvents() {
	subscribe(app, appTouchHandler)
	subscribe(contact, "contact.open", eventHandler)
	subscribe(contactClosed, "contact.closed", eventHandler)
	subscribe(acceleration, "acceleration.active", eventHandler)
	subscribe(motion, "motion.active", eventHandler)
	subscribe(mySwitch, "switch.on", eventHandler)
	subscribe(mySwitchOff, "switch.off", eventHandler)
	subscribe(arrivalPresence, "presence.present", eventHandler)
	subscribe(departurePresence, "presence.not present", eventHandler)
	subscribe(smoke, "smoke.detected", eventHandler)
	subscribe(smoke, "smoke.tested", eventHandler)
	subscribe(smoke, "carbonMonoxide.detected", eventHandler)
	subscribe(water, "water.wet", eventHandler)
	subscribe(button1, "button.pushed", eventHandler)
	if (triggerModes) {
		subscribe(location, modeChangeHandler)
	if (timeOfDay) {
		schedule(timeOfDay, scheduledTimeHandler)
	if (song) {
		saveSelectedSong()
	loadText()
def eventHandler(evt) {
	log.trace "eventHandler($evt?.name: $evt?.value)"
	if (allOk) {
		log.trace "allOk"
		def lastTime = state[frequencyKey(evt)]
		if (oncePerDayOk(lastTime)) {
			if (frequency) {
				if (lastTime == null || now() - lastTime >= frequency * 60000) {
					takeAction(evt)
				else {
					log.debug "Not taking action because $frequency minutes have not elapsed since last action"
			else {
				takeAction(evt)
		else {
			log.debug "Not taking action because it was already taken today"
def modeChangeHandler(evt) {
	log.trace "modeChangeHandler $evt.name: $evt.value ($triggerModes)"
	if (evt.value in triggerModes) {
		eventHandler(evt)
def scheduledTimeHandler() {
	eventHandler(null)
def appTouchHandler(evt) {
	takeAction(evt)
private takeAction(evt) {
	log.trace "takeAction()"
	if (song) {
		sonos.playSoundAndTrack(state.sound.uri, state.sound.duration, state.selectedSong, volume)
	else if (resumePlaying){
		sonos.playTrackAndResume(state.sound.uri, state.sound.duration, volume)
	else {
		sonos.playTrackAndRestore(state.sound.uri, state.sound.duration, volume)
	if (frequency || oncePerDay) {
		state[frequencyKey(evt)] = now()
	log.trace "Exiting takeAction()"
private frequencyKey(evt) {
	"lastActionTimeStamp"
private dayString(Date date) {
	def df = new java.text.SimpleDateFormat("yyyy-MM-dd")
	if (location.timeZone) {
		df.setTimeZone(location.timeZone)
	else {
		df.setTimeZone(TimeZone.getTimeZone("America/New_York"))
	df.format(date)
private oncePerDayOk(Long lastTime) {
	def result = true
	if (oncePerDay) {
		result = lastTime ? dayString(new Date()) != dayString(new Date(lastTime)) : true
		log.trace "oncePerDayOk = $result"
	result
// TODO - centralize somehow
private getAllOk() {
	modeOk && daysOk && timeOk
private getModeOk() {
	def result = !modes || modes.contains(location.mode)
	log.trace "modeOk = $result"
	result
private getDaysOk() {
	def result = true
	if (days) {
		def df = new java.text.SimpleDateFormat("EEEE")
		else {
		def day = df.format(new Date())
		result = days.contains(day)
	log.trace "daysOk = $result"
	result
private getTimeOk() {
	def result = true
	if (starting && ending) {
		def currTime = now()
		def start = timeToday(starting, location?.timeZone).time
		def stop = timeToday(ending, location?.timeZone).time
		result = start < stop ? currTime >= start && currTime <= stop : currTime <= stop || currTime >= start
	log.trace "timeOk = $result"
	result
private hhmm(time, fmt = "h:mm a")
	def t = timeToday(time, location.timeZone)
	def f = new java.text.SimpleDateFormat(fmt)
	f.setTimeZone(location.timeZone ?: timeZone(time))
	f.format(t)
private getTimeLabel()
	(starting && ending) ? hhmm(starting) + "-" + hhmm(ending, "h:mm a z") : ""
// TODO - End Centralize
private loadText() {
	switch ( actionType) {
		case "Bell 1":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", duration: "10"]
			break;
		case "Bell 2":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/bell2.mp3", duration: "10"]
			break;
		case "Dogs Barking":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/dogs.mp3", duration: "10"]
			break;
		case "Fire Alarm":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/alarm.mp3", duration: "17"]
			break;
		case "Matts Custom Airplane Ding":
			state.sound = [uri: "http://www.orangefreesounds.com/wp-content/uploads/2018/02/Airplane-ding-dong.mp3?_=1", duration: "4"]
			break;
		case "A door opened":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/a+door+opened.mp3", duration: "1"]
			break;
		case "There is motion":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/there+is+motion.mp3", duration: "1"]
			break;
		case "Smartthings detected a flood":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+a+flood.mp3", duration: "2"]
			break;
		case "Smartthings detected smoke":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/smartthings+detected+smoke.mp3", duration: "1"]
			break;
		case "Someone is arriving":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/someone+is+arriving.mp3", duration: "1"]
			break;
		case "Piano":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/piano2.mp3", duration: "10"]
			break;
		case "Lightsaber":
			state.sound = [uri: "http://s3.amazonaws.com/smartapp-media/sonos/lightsaber.mp3", duration: "10"]
			break;
		case "Custom Message":
			if (message) {
				state.sound = textToSpeech(message instanceof List ? message[0] : message) // not sure why this is (sometimes) needed)
			else {
				state.sound = textToSpeech("You selected the custom message option but did not enter a message in the $app.label Smart App")
			break;
		default:
			break;
i left some custom sounds in the code too.
Thanks Matt, that is the same code that I also modified with additional sounds. I think it is just the Speaker Notify portion but it works.
He are the ones I added, if anyone is interested. A little more “traditional” but I wanted a doorbell sound for areas of my house where the actual doorbell can’t be heard like the basement.
Alarm https://www.arnb.org/sounds/alarm.mp3
Chime https://www.arnb.org/sounds/chime.mp3
Doorbell https://www.arnb.org/sounds/doorbell.mp3
Siren https://www.arnb.org/sounds/siren.mp3
Edit: It just hit me that the Speaker Companion is just a Parent Smart App for the three speaker related smart apps (Duh!).
I love how hard we all work to make the digital doorbells sound like analog.
