am I the only one that isn’t able to add any Sonos?
I got a surround (2x Play 1 - Soundbar - Sub), a ConnectAmp and a Play 5.
Lan is the same for the flat (192.168.1.XXX / 255.255.255.0)…tried to disconnect, reboot, nothing.
The hub just can’t find one…
I ran into this issue when I had things in different VLANs. The ST hub, Sonos and the device you’re playing from all need to be in the same VLAN. Once I got that straightened out everything worked perfect.
Many thanks Christopher.
Unfortunately there’s no Vlan or managed switch. Is just a normal a router, plus a small 8 ports netgear switch…
so a very simple network.
