Sonoff Orb 4-in-1 Smart Scene Switch Integration
I have purchased a Sonoff Orb 4-in-1 Zigbee Smart Scene Button (model SNZB-01M) and cannot get it to work with Smartthings. It pairs as a “Zigbee Thing” but has no functionality. I expect that it will require a driver that may not exist. I’d like to hear if anyone has been able to use this device with Smartthings?
You can try the sonoff button driver at the following channel
Thank you for your suggestion, Paul.
I have installed the “zigbee-sonoff-button” driver from the “obmaz channel”.
I have also installed the “RDG - Zigbee Button” driver from the “STE-roadDOG” channel.
However, neither appears on the device’s driver list when I try to select a different driver via the phone app or web interface.
The device is stuck with the “Zigbee Thing” driver.
Install SNZB01M driver from Sonoff “official” drivers (Driver list is at end of the page)
Sonoff SmartThings Edge Drivers
Sonoff Channel Information
Also the Sonoff driver list is at end of the page here:
Thank you both for guiding me to the correct driver location.
Everything is working now.
Thank you very much!
I hope you could share your experiences using the device after you have used it for a while. I don’t have the device in use but the device seems interesting.
It would be good to have screenshots of the detail view and routine conditions.
OK, I will report back when I have put the device through its paces. So far, it seems to be doing everything as advertised.
I couldn’t find the driver at the link above.
Anyway, since I already created the driver, here’s the link: link
I believe there shouldn’t be a problem having two drivers hahaha
If you couldn’t find the link, here is one for you:
Thanks for creating your driver.
Actually, I couldn’t find the official Sonoff driver when I first looked last week, but I did after following TapioX’s prompt. I’m thinking it was added late.
Do you have the device, and how are you finding it to use?
Zigbee Button Driver also supports SNZB-01M
SONOFF
  • id: “SONOFF/SNZB-01M”
    deviceLabel: SNZB-01M
    manufacturer: SONOFF
    model: SNZB-01M
    deviceProfileName: four-buttons-battery
