Hello, I’m new with lua and Edge driver. As a start, I wrote a simple driver based on ESP8266 Sample Driver, using UDP, but there is a error.
2022-03-08T05:51:49.462837524+00:00 INFO Dummy Driver SERVER start
2022-03-08T05:51:49.489851524+00:00 INFO Dummy Driver SERVER running on 192.168.100.6:53053
2022-03-08T05:51:49.500790857+00:00 FATAL Dummy Driver Lua: runtime error: [string "cosock/socket/internals.lua"]:56: attempt to index a nil value (field 'wakers')
stack traceback:
[string "cosock/socket/internals.lua"]:56: in method 'receivefrom'
[string "server.lua"]:18: in field 'start'
[string "init.lua"]:58: in main chunk
My code is looks like:
server.lua
local log = require "log"
local socket = require('cosock').socket
local server = {}
function server.start(driver)
log.info("SERVER start")
local sock = assert(socket.udp())
local ok, err = sock:setsockname("*", 0)
if not ok then
log.error("failed to bind server: " .. err)
return
end
log.info(string.format("SERVER running on %s:%s", sock:getsockname()))
while true do
local buf, ip, port = sock:receivefrom() --> THIS LINE TRIGGER ERROR
print(buf, ip, port)
end
end
return server
And use the server
init.lua
--- smartthings libraries
local Driver = require "st.driver"
local capabilities = require "st.capabilities"
--- local modules
local server = require "server"
local function device_added(driver, device)
log.info("[" .. device.id .. "] Adding new Hello World device")
device:emit_event(capabilities.switch.switch.on())
end
local function device_init(driver, device)
log.info("[" .. device.id .. "] Initializing Hello World device")
device:online()
end
local function device_removed(driver, device)
log.info("[" .. device.id .. "] Removing Hello World device")
end
local function command_handler(driver, device, command)
end
local driver = Driver("Empty Driver", {
discovery = function (driver, _)
driver:try_create_device({
type = "LAN",
device_network_id = "hello thing",
label = "Hello World Device",
profile = "hello-world.v1",
manufacturer = "SmartThings",
model = "v1",
vendor_provided_label = nil
end,
lifecycle_handlers = {
added = device_added,
init = device_init,
removed = device_removed
capability_handlers = {
[capabilities.switch.ID] = {
[capabilities.switch.commands.on.NAME] = command_handler,
[capabilities.switch.commands.off.NAME] = command_handler,
driver:run()
What is matter with this code?
