great i forgot that option to change logging level
ok reproduced the issue on one of my dashboards if i leave it for a moment it stops refreshing. FYI I use tasker to shut off the screen and proximity wake it using motion detector, it always used to be when the screen switched on a refresh occurred. the device itself does not go to sleep its just the screen that gets shut off.
ok so the first three lines appear periodically. when i walk in front of the screen and the screen switches on nothing happens in the live logging window, so i then press the refresh button on the screen and i get all the following lines but the screen itself does not refresh, everything is effectively stuck (clock, icons etc.)
can you see anything from this log excerpt?
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace rendering tile [tile:device, active:inactive, type:switch, device:7eec68d5-6bd2-4030-9dbd-60e44fdc25c6, name:Conservatory Manual, value:off, level:null, isValue:false]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace rendering tile [tile:device, active:active, type:momentary, device:9452b58e-b4aa-445d-a38f-47be0e94e71a, name:Dinners Ready, value:null, level:null, isValue:false]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace rendering tile [tile:helloHome, phrases:[Away, Good Morning!, Good Night Cats Roaming, Good Night Holiday, Good Night!, I'm Back!], name:Routines, type:hello-home]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace rendering tile [tile:mode, mode:Home, isStandardMode:true, modes:[Away, Home, Manual, Night, Night Holiday, Party], name:Mode, type:mode]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace rendering tile [tile:clock, size:2, style:d, date:March 14, dow:Monday, name:Clock, type:clock]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace tile count: null
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData end
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected links
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected battery
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected power
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected energy
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected water
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected luminosity
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected humidity
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected temperature
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected video streams
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected camera
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected acceleration
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected motion
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected presence
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected contacts
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected momentaries
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Dinners Ready, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Dinners Ready, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Dinners Ready, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory White-Orange, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory White-Orange, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory White-Orange, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Red-White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Red-White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Red-White, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Play Pool, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Play Pool, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Play Pool, momentary
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Spot 3, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Spot 3, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Spot 3, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Spot 1, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Spot 1, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Spot 1, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Behind Sofa, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Behind Sofa, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Behind Sofa, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Garage, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Garage, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Garage, dimmerLight
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected dimmers
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected themeLights
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected lights
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace allDeviceData collected switches
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Lights, switch
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceValue Conservatory Lights, switch
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace isActive Conservatory Lights, switch
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:35 PM: trace getDeviceLevel Conservatory Manual, switch
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:34 PM: debug params: [ts:1457995266712, stateID:1457995266713, _:1457995483282, access_token:XXX-XXX, appId:180b0b5f-74bd-4818-a2be-b311e8174535, param1:ping, action:[GET:executeSmartAppGet, POST:executeSmartAppPost, PUT:executeSmartAppPut, DELETE:executeSmartAppDelete, OPTIONS:executeSmartAppOptions], controller:smartAppApi]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:25 PM: debug params: [ts:1457995266712, stateID:1457995266713, _:1457995483281, access_token:XXX-XXX, appId:180b0b5f-74bd-4818-a2be-b311e8174535, param1:ping, action:[GET:executeSmartAppGet, POST:executeSmartAppPost, PUT:executeSmartAppPut, DELETE:executeSmartAppDelete, OPTIONS:executeSmartAppOptions], controller:smartAppApi]
180b0b5f-74bd-4818-a2be-b311e8174535 10:46:04 PM: debug params: [ts:1457995266712, stateID:1457995266713, _:1457995483280, access_token:XXX-XXX, appId:180b0b5f-74bd-4818-a2be-b311e8174535, param1:ping, action:[GET:executeSmartAppGet, POST:executeSmartAppPost, PUT:executeSmartAppPut, DELETE:executeSmartAppDelete, OPTIONS:executeSmartAppOptions], controller:smartAppApi]
