tgauchat
124
Hi Jeff⦠Are you in the US or UK? I presume last version of the Hub or �
It is also worth trying to add another tile or two and/or try a different kind of Tile.
This could also be a temporary SmartThings problem, but I figure that would impact more users.
If you know how to use SmartThings API/IDE Live Logging, thatās what weāll need to diagnose. If you need assistance with that, email: Support@SmartTiles.click
@tgauchat Correct, on Routines/Modes. First tap the menu comes up briefly and goes away. Second tap works as it should. Running on iPad Mini 9.1. Just tried on Safari om my Iphone 6s and works perfectly.
tgauchat
132
Weāre still waiting for someone to donate an iPad to SmartTiles so that we can debug ā¦
I think weāre searching for one to borrow in the meantime. Hope it replicates the error; though then we still might need a Mac with iOS development kit or something to debug. Weird Safari web engine glitch?
For what itās worth, I installed a few different browsers on my iPad mini tonight to see if the issue was browser specific. I was able to replicate the issue in the following browsers outside of Safari. Dolphin, Google Chrome, and Firefox.
However, still works as it should on the iPhone. It may as well be a compatibility issue between ios9 and first gen mini. Performance took a big hit once o updated to the latest software. Wish I could go back to 8.4, but Apple quit signing the firmware.
tgauchat
135
Hi Nicholas,
Youāre the only person that has reported this issue on an Android device. Can you double check? What version of Android and browser, please?
Thanks for all that testing. Iām not that familiar with iOS ⦠do all the browsers use some of the same underlying library / rendering / input components? I would guess so⦠probably more likely than on Android.
It is helpful that this is observed with other browsers, though, because thereās a chance the other browser apps will have better debugging options.
just for curiosity @625alex@tgauchat is there any chance that SmartTiles 6 can be released before Xmas?
thanks
fab
tgauchat
137
In the spirit of trying to never make a promise I canāt keep, I can definitely say that thereās less chance of SmartTiles V6 public release than the probability that there will be a Hub V1 to Hub V2 migration tool āby the end of the yearā.
At some point will we be able to create selectable custom themes under SmartTiles 6 or is that option at least on the radar of a distant future of possiblities?
@sballoz, I would say that there is no chance of a pre-Christmas release. We wonāt release a half baked product. Meanwhile, we intend to fully maintain version 5.
Thereās something with your name on it that is going to be released in the coming weeks ⢠though, so thereās more to look towards to.
That is our goal and hope. A lot of features that were just an afterthought turned out to be the most compelling features of SmartTiles. Custom themes was such a a feature. If I new how popular customization would become, I would wire up the CSS differently. It should definitely be easier in the next version, but please donāt expect it on day 1.
tgauchat
140
Hi Jeff⦠The Live Logging output offers a small clue worth investigating.
Line 1060 is related to fetching your list of Routines for use with the Routines Tile. Unfortunately, the list is fetched even if you disable the Tile.
Anything unusual about your Routine Names? Do you have a long list? Empty names? Duplicate names? (We suspected that an empty list of Routines could be the cause, but ⦠nope⦠empty list is fine in our tests). Still⦠something about Routines⦠maybe.
Feel welcome to email me to follow-up in more detail: Support@SmartTiles.click
So I just installed SmartTiles on my iPhone 6 and ran it, keep in mind I also have my smartthings app on the same phone. I ran a simple dash with just one dimmer switch to see how it will work and pushed the button to turn on the lights and it didnāt work. I then tried to tell Amazon echo - Alexa to turn on the same lights it didnāt work anymore. Alexa was always able to turn on the same light prior to the SmartTiles.
I uninstalled the SmartTiles app and regained control of the light with Alexa after some time.
Are the two competing for the control of the system?.
tgauchat
143
I run both Alexa and SmartTiles on my phone and havenāt observed this behavior, but canāt rule out interference because SmartThings can do some really weird āout of specā things sometimes.
I think this requires some more testing to really make sure to isolate the error.
Hereās the facts (?): Amazon Echo/Alexa connects to SmartThings using āAmazon Cloud <-to-> SmartThings Cloudā communication. That means the Alexa App connected to SmartThings on your phone, never actually talks directly to SmartThings. The SmartTiles dashboard, however, runs in your phoneās browser and is a direct āBrowser <-to-> SmartThings Cloudā connection. This means SmartTiles can interfere with other SmartThings connections within the same browser session; but it should not interfere with any other Apps (unless they are really browser sessions) or any other Clouds (like Amazon).
Make sense?
Now there are a lot of quirks in the SmartThings Cloud that could be unrelated to SmartTiles & Alexa specifically here too. Both can malfunction if SmartThings doesnāt report the most current āStateā of the Switch. This is an across the board problem ⦠for example, if I use an Aeon Minimote to turn a light on or off, I sometimes have to ask Alexa twice to control the same light. I think this should be considered a bug, but I have to make that 100% reproducible before I report it to SmartThings support.
But the purpose of posting here is to see if anyone else is observing the problem you described.
I have asked this previously and was told that YES it will be doable one day, but not until atleast V6 so yes they plan to be able to do this type of customisation eventually which i agree is fantastic !
