Please help me figure out what I am doing wrong here.
I created a virtual switch in Smartthings and I am using it in WebCore to perform a number of things that I am calling “Good Morning”. I can run the switch from the Smartthings app just fine. I told Google to sync devices. When I tell Google Assistant “Hey Google, Good Morning” it doesnt run the piston I created in WebCore but gets confused and runs the default Google Assistant routine named Good Morning. I have the same thing setup for “Good Night” and it works just fine.
Is there anyway to tell Google Assistant to not run its routines but use the action from Smartthings?
I discovered last night that if I said “Hello Google, run Good Morning” then it would run the routine. Is there a way to set this up so I dont have to say “run”?
