SmartThings V2 hub STH-ETH200 Solid Blue LED
I have a V2 Hub that I did the Factory Reset to. The reset went as expected, and I have reset it again twice to see that it is reset OK. The issue is now that it is reset it boots to a blue flashing and then stays solid Blue. Which states its not connecting back through the intranet. I can see its IP on my network and have another working V2 hub on the same network. The SN is 3000373020 if that helps.
I was trying to add it to a second location and that is not working.
one possibility is it could have an expired security certificate.
things to try:
  • block port 123 udp on your Router
  • reset the hub and onboard the hub to the app
  • unblock port 123 udp
  • if you don’t have the ability to block port 123 udp than block the domain ntp.org and follow the same steps above. Many hubs have a perental control option that allows you to block domains.
if your hub does not allow you to block ports or domains, you should find a friend or family member who has a network that allows it.
Thanks jkp,
That was exactly what I needed to do. Now that you explained it, I can understand why the temporary block allows the V2 updates to get installed. Once installed it when green and allowed me to add it to my app.
