This appears to be happening again, or maybe it was always happening.
For some reason my Yamaha loves DLNA playing mp3s off s3 but refuses to do any of the TTS apis I plugged into it. Which means no weather for me yet… Ideas?
Hi @Kristopher, I have launched a mediarenderer events smartapp and Weather Forecast , They have a new Text to speach alternative, works great form me, no more problems, I hope smarthings fix the TTS but in the meanwhile this alternative is an option.
Hey @ule - I saw that and appreciate it. I used voicerss and tried some others as well – for whatever reason my receiver doesn’t work with that provider. It does not work with Google TTS either for some reason, but it can play MP3s off S3 just fine. Looking into it more
HI @chrisb, have you tried this workaround, it use google speeach and Voicerss service to allow text to speech, it works great form me, but its necessary to register in voicerss service, you can test the apps I have mod with this function.
Hi @chrisb, Yes, its a good method, but this method calls the texttospeech function inside the device type, this function is the official function and have problems, if you are using sonos or samsung speakers it going to fail (until ST fix the function) if you are using the latest DLNA media renderer, it use the fix, but you can send the url text audio to playTrackAndResume(uri, duration, volume) command and use the fix before send to speakers, check the code of Sonos Weather Forecast External TTS to known how to use the function
[quote=“ule, post:68, topic:20142, full:true”]
Hi @chrisb, Yes, its a good method, but this method calls the texttospeech function inside the device type, this function is the official function and have problems,[/quote]
Ah… okay, that makes sense. I didn’t understand how device.speak and texttospeech() related.
Hmm… I thought I was using the latest version… maybe not though. I’m pushing text through to my tablet running Bubble Upnp. I’ll have to double check if I’m running the latest.
Okay… so I didn’t have the external TTS turned on in my device. I edited the device and saw the option. Turned it on. Yeah! Now I’ll just need to test tonight and see if it works.
So when will the textToSpeech() function be resolved?
textToSpeech() is the function that translates desired text phrases and returns audible files (mp3) to be played by connected SmartThings devices.
In it’s current state, when called, it often throws a terminating error stating “java.lang.reflect.UndeclaredThrowableException” if the requested phrase/audible file is not already cached on SmartThings servers. Sometimes it will convert and cache the phrase properly and then when the same phrase is called, it will work from then on, but most of the time new phrases throw this error and the SmartApps that rely on this function stop processing at this point (unless they use a try/catch routine).
I am handling this with a try/catch and notify in in the latest BigTalker SmartApp, but it would be nice for the issue to be resolved once and for all for all apps.
This has been an issue for many months! Why has it not been prioritized and resolved yet?
Related threads:
and so many more threads…
Please, SmartThings, resolve the issues with textToSpeech().
I remember someone from ST mentioning that they are working on overhauling their TTS feature. I hope that overhaul fixes it and does not break it even further.
Up until very recently I was using my Ubi for all my voice announcements. Once I got Echo I was looking for ways to phase out my Ubi and rewrote my “Goodnight” app to use TTS.
Unfortunately it looks like I might have to switch back to Ubi until this gets fixed.
I know that ST has a lot going on all the time and this is surely just one issue, but I do think it’s a relatively big issue because it’s one of the ways that helps being HA to a more comfortable level. If we’re getting voice announcements of events rather than push notifications or text notifications this makes it feel more familiar and means we don’t need to stay glued to our devices when at home.
