I did the reset. Can you check if it worked? Thank you very much for the help
Thank you so very much!!!
Hi @aknipp
I sent you the welcome code through a DM
Hi @nayelyz , is it possible to get the welcome codes for my two hubs I no longer have the boxes for please: 4000312112 and 4000312332. Thanks in advance!
Howdy!
Could you fine people help me with my code as well? If so that would be swell.
SN#: 4000103889.
I attacked the factory reset button with fervor and stamina, so hopefully it will be reset properly.
Thank you!
@Ole_Oye
Hi, @cristi.grigore
I sent you a DM with the welcome code of both hubs.
Could I get a welcome code? Sn 3000373087
Hi,
I reviewed your Hub, and it appears as ‘CLAIMED.’ This means it is already installed on the SmartThings platform, and you won’t be able to claim it with another account. Here are some instructions to reset the Hub:
- Connect the Hub via ethernet
- Then, follow the steps to factory reset it. Here’s a link that has the instructions for different models:
Factory reset or reboot your SmartThings Hub
Hi Itati - can I ask the same question as everyone else? SN 3000364593. Thank you!
Hi, @Alyssa_Jayne
We see that this hub was claimed a few minutes after you posted here, so, I just want to confirm you got the Welcome Code.
Hi, @Lhqc.
I sent you a DM with the Welcome code, please let us know if you have any issues
Hello Support Team,
Can you help me with my samsung smartthings 2015 V2’s welcome code ?
Model is STH-ETH-200
Serial number is # is 3000132003
Thanks!!
Hi dear Support Team,
Can you please help me with my samsung smartthings welcome code?
Serial number is # is 3000399666
Thanks in advance for your kindly support.
Hi, @mik.lopz. I sent you a DM with the welcome code.
It was added successfully… Thanks.!
Hi, I hope this is still active. I need a welcome code for V2 hub SN 3010156769. Thanks!
Hi, @la975
I sent you a DM with the Welcome code, please check your inbox.
