For those who have setup STHM in the new app. How did you separate the old app’s routines into automatons and scenes?
I configured virtual switches to run automations and scenes which includes arming and disarming STHM. I mainly did it that way so I could still use ActionTiles. Took a minute to get used to, but it works.
Generally speaking as I work through mine, the things you want to happen ade scenes and the things that trigger those are automations.
Basically the same “logic” that the routines had, but put into an IF and THEN format. Although I did split the STHM to a separate automation based on Mode for some reason…can’t remember why. I think it’s because I had multiple ways to determine Home and Away mode but always wanted STHM to follow it.
Here’s how I do it, just click to open the post.
