SmartThings Energy dashboard
Hello,
What is the correct way to integrate a Power plug with energy consumption monitoring in the Energy Dashboard?
Currently, only my Aqara Smartplug is used, and I would like to integrate a Zigbee Energy counter that is connected to my main Energy meter.
Unfortunately, at the present time only Samsung smart appliances and a very few other devices can be included in the Energy dashboard. :disappointed_relieved:
As you noted, the Aqara plug is one that works, no one seems quite sure why. Even the SmartThings brand models don’t show up. It’s a mystery. :thinking:
You can try asking support. If you get an answer, let us know.
https://support.smartthings.com/hc/en-us
Here is a previous conversation about the topic, FWIW:
I have an Aqara smart plug, but it doesn’t show up in Life- energy
Is there some step I need to take?
Could it also be used an an energy level trigger ST automations
I don’t know about the Aqara smart plug, but the Samsung SmartThings Outlets can be used as a trigger in routines, e.g. “Power Meter” “Equal or above” (or “Matches” “Equal or below”, “Range”) which I use to see if AV kit is being used or just in standby mode and can therefore be switched off until used. The Aqara might (should?) be the same.
