SmartThings Auth Token Get Needed in my website to call SmartThings API
There is feature that when login via GoogleDrive , OneDrive etc.
They will provide one UI for username and password and after successful login it provides us auth token/ refresh token.
want provide my own service (eg. a web page) to allow users to control the devices installed in their SmartThings account.
But in SmartThings documentation i did not found any endpoint URL where i can hit and login and then my app/server get access token so that i can use it for calling SmartThings API.
I do not want to use PAT, I use only auth.
So please help me with this.
Hi @Devesh Welcome to SmartThings
you can start with a SmartApp to see the flow of authentication
After that, you can move to OAuth integrations to share it with other users
Note: OAuth integrations have some limitations, for increased permissions you will need to send a form
@AlejandroPadilla
Is it necessary to create SmartApp ?
My website cannot work as SmartApp?
Means if i do not want any middleware, how my website directly talk with ST Cloud using OAuth 2.0.
@Ivan_Luis_Falleau
Can you please help me
@Devesh sorry for the delay I was out of the office
  • For the first question: yes is necessary to create OAuth-In SmartApp to utilize OAuth.
  • For the second question: the smartapp-sdk-nodejs is a library to libraries for building Webhook and Lambdas to interact with the SmartThings Public API, we recommend using it, but you also can send commands to the Public API with the correspondent token.
