Everything looks good except Iām hitting a snag on why I wanted to check this API browser out. It looks like the driver section under devices is showing up blank.
Iāve created a couple additional tokens providing all access to my hubs, but it doesnāt seem to be populating with any entries. I was hoping to use this to map out which drivers were being used where. Iām wondering if there was anything that I missed that could have caused this?
It is probably worth giving a little info on how this area of the API plugs together.
The /drivers endpoint returns the drivers that you (by which I mean the Samsung/SmartThings user that generated the PAT you are using - the āprincipalā) created yourself. Every other driver, even those created by other members of your SmartThings Location, is a third-party driver and is not accessible to you via /drivers.
Similarly the /distchannels endpoint (which allows for more than just channels of drivers) returns the channels that you created yourself. However you actually have access to any channel that you (again specifically the principal of the PAT) have subscribed to, by which I mean you accepted an invite to. You can see all of those by accessing /distchannels?includeReadOnly=true, and if you do you may find yourself wishing there was an āunsubscribeā because all the extant channels that youāve ever subscribed to are there. You can also see the Production Default channel as that is a special case that doesnāt need a subscription.
You can drill down into /distchannels to see which drivers are in each channel (/distchannels/{{channelId}}/drivers) and you can also see the metadata of each driver which includes the fingerprints (/distchannels/{{channelId}}/drivers/{{driverId}}/meta). Remember thatās only for the channels you have access to as mentioned above.
When it comes to looking at the channels and drivers associated with your hub you are looking for /hubdevices/{{deviceId}}/channels for the channels each of your hubs is enrolled in (which doesnāt include the Production Default channel), and /hubdevices/{{deviceId}}/drivers for the drivers installed on each of your hubs (and note that /hubdevices doesnāt do anything useful, you have to get the ID from /devices first). The channels give you the name, description and subscription URL for each channel but if you want more you have to use the channelId it gives you with /distchannels. Similarly the drivers give you the name, developer and the channelId they were installed from for each driver and if you want more you have to go hunting for it armed with the driverId.
I guess what I am trying to convey is that a lot of seemingly straight forward queries from a user point of view actually have to be anticipated as they need bespoke handling and security can get in the way sometimes.
The easiest way to find what has NOT converted, is to use menu: Devices/Devices. Then click on Filter and choose Device Type and DTH. That will return all devices that are using an OLD DTH as the driver.
@TAustin Iāve now created a couple of āVirtual Locksā, because they come in handy as they can trigger Alexa routines which I need.
It seems that when you create them they are assigned a random battery % level? Any way to crick this up to a permanent 100% battery level, because now Iām constantly getting messages that battery levels are low⦠Which makes no sense for a virtual device
I donāt currently provide a way to set that value within this app, but to me, the right thing to do is have the SmartThings team fix it.
@nayelyz - Could you please put a request in to the team that when you create a virtual lock through the API, that the battery state value needs to be set to 100% rather than a seemingly random number that can often trigger low-battery notifications?
In the meantime, you have a few choices:
If you have the CLI you could use it to update the battery value
If you have a hub, you could alternatively use my vEdge driver. With that you have further choices - create a virtual lock (that does not included a battery), or create an Alexa switch device with an an optional contact that can be used to trigger Alexa.
Also if you have a hub, use my Alexa Multi-trigger driver which uses a slightly different approach that could work for you. Read more info at that link, and here.
Are we talking about the āVirtual Lockā you can create via /virtualdevices/prototypes (which is smartthings virtualdevices:create-standard in the CLI)? I know that āVirtual Lockā includes the battery capability and the default attribute value seems to be random.
If so then I donāt quite see the problem as you can set your preferred value via /virtualdevices/{{deviceId}}/events (or smartthings virtualdevices:events).
Thanks for the alternative options, since I have no programming knowledge (dont know how the CLI works) and I have no intention of buying a hub, the above options are not an easy option for me.
What I did now is turn off notifications for all the specific virtual locks and it does the trick as well.
@orangebucket thanks for the tip, Iāve created the virtual locks using this API browser+ from TAustin, I have no real understanding to whatās behind it, but I guess its kind of explained in this topic subject.
