Last issue (Motion sensor didn’t trigger wall plug ect ) showing me ST can’t working (local) with any device , this is a bit strange coz other systems like fibaro can working at local if no internet connection.
Just wonder there is any option to update device to let it work local if no internet connection? I mean still should be log events at home , or st should be able to trigger some rules like motion sensor trigger plug ect .
Currently only SmartThings published devicetypes for Z-Wave and Zigbee devices will run locally. Also, only the SmartLighting App and some parts of SHM will run without an internet connection. There has been discussion about there being a submittal process to get other SmartApps and devices added to the list of things that are locally run but I haven’t seen anything about that recently.
problem is , when I’m disconnect lan nothing working in my ST , i check yours link but in my st is no devices running local ? why?
multisensors not working local ,motion detectors too , there is anything wrong in my ST?
That’s very strange. As long as you installed them using the default device-types then they should show up on the Devices list I posted above…[quote=“blebson, post:2, topic:35719”]
Your locally installed Devices: https://graph.api.smartthings.com/localDevice/list
[/quote]
reset and re do again all the devices and see if that work.
my devices show as local and i have smart lighting as local app. i have 6 ge link bulbs. they show as local. in smart lighting app i configured those bulbs and set to turn on when i click the bulb 1 but it does not work locally.
guys maybe i don’t understand that properly , with no wifi router only hub v2 ST sensors should work or not? or maybe wifi router is required ? I’m lost a bit
I found you need to change the device type to make it work local. If you edit the device in the web and change the device to SmartSense Motion/Temp Sensor from SmartSense Motion Sensor that caused it to appear in the local devices list.
