I’ve been using the Smarthings API in earnest but a couple of things I can’t figure out:
Is it only possible to bring back one device [full] status at a time - it is very call intensive when the JSON doc could bring back all devices ?
Where is the historical log data for each device event on the API - I cannot see an end point to get this data for a device ?
Seemingly the device Health is not being captured into the API endpoint. While you can see it on the portal it does not come through on the JSON document populated.
I believe that is correct, or at least that is all that is documented. I guess how intensive you perceive it to be rather depends on which end of the call(s) you are.
