Smarter Coffee and iBrew (includes DTH links)
Does anyone have this working with gen1 coffee machine ? my Ibrew server works and I’ve cloned Jonbur’s repo which (I believe) has the extra bits to allow the DTH to talk to the iBrew server
When I toggle the coffee machine device power in ST app (new one) I can see in iBrew logs incoming requests from the ST hub however, the IDE log gives me :
unknown response: [sensors:[hotplate:false, waterlevel:2, grinder:false, heater:false], status:[timerevent:false, carafe:true, cups:0, enoughwater:1, working:false, ready:true], settings:[carafe:required, default:[hotplate:40, cups:2, source:beans, strength:medium], current:[hotplate:40, cups:2, source:beans, strength:medium], mode:carafe], appliance:[firmware:[certified:iBrew certified firmware, version:22], model:Smarter Coffee, network:[connection:[port:2081, directmode:false, host:192.168.0.29, relay:false, connected:true], relay:[port:2081, active:false, bind:]], mode:normal]]
Under a different Smartapp. I think this might be due to the mac routing mentioned but I’ve set the ibrew server mac as B827EBD2E589 which I believe is the correct syntax…
