Any new smart vents working with ST?
I see Keen, but looks like you need their bridge and sensors.
Have Zooz sensors in all rooms.
My thermostats are Honeywell TH6320ZW2003.
Keen use Zigbee and work directly with a SmartThings hub
This is true. I have several Keen vents in my house, and I control them with webCoRE.
Hello, I would like to use a Keen vent directly connected to smart things hub and use it in a simple manner.
Just open vent at 600 am, shut vent at 6 pm. Just like a light switch. ( this is for a basement home office).
Is that doable. I cringe seeing issues people have with a full integration with a thermostat and keen sensors. I am not ready for that yet.
Any advice is greatly appreciated
It connects to SmartThings over Zigbee, and looks like a dimmer. Just set up an automation to open and close at the times you want.
Connected by Zigbee to ST directly, Can I use a Zooz 3-1 sensor to control the vent from WebCore? Example:
If Room A is not at temperature then
Close room b, c, d, e
Trun on thermostat (AV or Heat)
end if
Awesome, thank you!!
The vents show as dimmers, so you can do whatever you want with them. That is, as long as the Groovy environment that WebCore uses is still around.
I currently control my vents through WebCore using the Ecobee remote sensors. I use this piston, with one for each room/temp sensor (some pistons control multiple vents off one temp sensor); it might not be the most elegant thing, but Iām not a programmer, and it works. (Note: I have the piston retrieve the thermostat setpoints in the logic because the setpoints will change throughout the day, and I want the vents to adjust to the room temp vs setpoint.) I have a separate piston set a global variable for heating or cooling, and the vent piston refers to that. Green images of both pistons below.
