I got a new Smarthings Arduino shield . Though it pairs, I am unable to run stLed example (the first one I am trying with). I debugged this extensively and convinced that the issue is hardware related . My arduino (galileo gen2) has 2 hardware serial ports, I adapted ST_anything library to fit this board.
I am seeing only the following output
`setup…
|<~ custom netinfo
UNKNOWN
|<~ custom rgb 0 2 0
|<~ custom netinfo
|<~ custom netinfo
Within the library run loop
`oid SmartThings::run(void)
uint8_t readByte;
//Serial2.write("New\n");
while ((_nBufRX < SMARTTHINGS_RX_BUFFER_SIZE) && st_available())
//-------------Code never entering here ---------------
Serial.write("In while \n");
readByte = st_read();
if ((readByte == 0x0D) || (readByte == 0x0A))
{ // handle data from SmartThing Hub line-by-line, execute user's callback function for each line
Serial.write("Newline\n");
handleLine();
else
Serial.println(readByte, HEX);
// keep track of everything that comes in until we reach a newline
// TODO(cwvh): validate bufferlength 1988-10-19
//if (_nBufRX > 200)
// panic("too many characters!");
_pBufRX[_nBufRX++] = readByte;
_process(); ---->the netinfo prints come from here
So it looks like the Shield is not sending / receiving data on pins 2/3 … shield jumper is set for 2/3. I even cross connected the 2/3 of arduino to 3/2 of shield just to be sure. I even swapped the debug and other serial port (and the jumper) and verified the output still the same (from debug port)
Any advice ?
