I have 2 skylights that are opened and closed using 3 way toggle switches like the one below. Is anyone aware of a smart switch I could use to automate the skylights? I would like to not only be able to manually open and close them using a smarthome integration, but I want to program them to open or close automatically based on indoor temperature and external windspeed.
In addition to @Automated_House’s question, when the switch is toggled in either direction, do you have to hold it there for the skylight to open/close and then it stops at your desired position when it returns to center?
One option I can think of would be to use FortrezZ’s Mimolite or MIMO2, but there are certain things to consider depending upon how that toggle operates:
