jkp
April 23, 2023, 8:34pm
13
eefrat2:
I went into my IDE
just be aware that IDE will be shutting down at some point. Also, it is not the best tool for managing devices. You can’t assign Placeholder in IDE to a device… does not work nor can you change devices assigned Placeholder to a DTH. The universe will collapse! OKAY, slight exaggeration
non-technical answer: the IDE is part of the old groovy based architecture. It will be going away and be replaced with something else. in the meantime, anything which is using the new architecture will be represented in the IDE with “placeholder“ under the device type column. This includes devices using an Edge Driver. Since new edge drivers are being added overtime, it may even be that a device which is the same model number as a device you previously added which used a groovy DTH is now using an Edge driver and so shows up as placeholder.
Don’t change it! Once the device is using an integration from the new architecture, you can no longer get to its code details through the IDE, And changing it to a different device type may break the integration altogether.
If you need to cha…
With the transition to the new architecture, the IDE is in the process of being discontinued. Some features are already gone. Any device using new architecture, such as those using edge drivers, will just show up as “placeholder“ and the information will be incomplete or even inaccurate. (For example, it will probably say that all devices showing “placeholder“ are in the cloud, where in fact all edge drivers run local.)
Don’t try to use the IDE to change anything that says placeholder: you might even break the integration altogether.
http://my.smartthings.com is the new official webpage access to your smartthings account.
At first that page was pretty limited, but as of 29 June 2023 Samsung has now added a number of new “advanced” features to that page, making it much more like the old …
